J
JM9
Hi,
A friend had a new outside garage built which required an electrical supply. He has installed a ring main in the garage for sockets and a radial circuit for the lights. This has been connected to a 4 way garage consumer unit with a 40A 30mA RCD with a 32A and 6A MCB's. The garage consumer unit has been connected to the main consumer unit in the house via 28 metres of 3 way 6mm SWA cable. The SWA is connected directly into a 40A MCB on the consumer unit via a metal junction box. The 40A MCB has been situated next to the main on/off switch for the consumer unit on the non RCD side of the consumer unit. The SWA has been connected directly into the plastic garage consumer unit. When he tries to switch on the RCD in the garage it trips immediately, does anyone know why this is happening? The SWA cable is live and he has used the earth tags on the internal glands for the plastic consumer unit and metal junction box and has used 6mm earth cable for this.
Many Thanks
Many Thanks
