M
melmid
im about to change an old rewirable garage cu for a rcd 2 breaker unit. It is fed from a breaker in the house cu.On the eic where they ask for supply protective device characteristic without removing the supply authority fuse which i dont need to do for the garage cu would writting not known be acceptable in this case
