J
jnybakers
hi guys
I am recently qualified and in the process of registering with elecsa.
as part of my assessment, i am installing a garage CU, 30m away from the main CU.
i intend on feeding it from a 32a mcb from the RCD side of the main CU
i will be running it with SWA and with a radial on 16a and lighting on 6a mcbs respectively to fees a couple of lights and 3 sockets.
my questions are:
1. is it ok to feed it from the 32a MCB
2. should i use 4mm or 6mm SWA
3. the customer has refused to pay for a trench digging as i advised it should be buried at leas 18". will it be ok to be run along a fence for some of the distance?
4. is it ok to feed the 16a and 6a mcbs for the radial and lighting respectively.
also he would like an out door socket near the main CU, I suggest a spur of f a ring final, but he wants it off the one going to the garage. can i feed the socket directly from the swa but with a fused spur?
any help will be appreciated just want to make sure i am doing the right thing for the assessment.
my questions are:
