sonasardar
Hi all,
i have re-wired a house to 17th edition,however the feed to the garage was not done because thr ground work was not being carried out.
The senario is this ,the garage is detached ,brick built ,about 10-15 metres from house.the old garage was fed with a 2 core swa i think 4mm buried underground.
i am hoping to use the existing swa ,the garage will have a light and 2x2 gang sockets.
i will have a 2 way metal clad cu in the garage,and hoping to use a metal box in the utility area to terminate swa and from there take a 4mm t&e to the consumer unit in the house on a 40a mcb on the non-rcd side.
Please advise. thanks
