Garage Heater Hardwire Help | on ElectriciansForums
Discuss Garage Heater Hardwire Help in the UK Electrical Forum area at ElectriciansForums.net
Chris5303
Indianapolis
I am a home owner that has a lot of previous success with some pretty heavy DIY projects including running a 100 amp box in the garage and adding 7 outlets on 3 breakers, etc.
That said I just purchased a Dimplex euh12b84ct and have not been able to get it running. Its 12.5 KW 600 Volt and I'm using the single phase option.
I've run it about 7 feet from the box from a 60amp 2 pole breaker with 2 6 gauge wires running from the hot to heater and and 8 gauge ground.
The fan turns on when the thermostat is below the room temp but that is all I can get it to do.
Power is getting to Contactor but I am not sure where to go from there on the Trouble Shooting. I have a Multimeter but I'm a bit of a novice with it.
Thanks for any help you can offer.
  • [ElectriciansForums.net] Garage Heater Hardwire Help
If the supply wiring is correct for single phase, check the limit stats marked C on the drawing are not tripped.
I assume the heater contactor is not pulling in?
I checked the fuses in part labeled C and they are not blown. Tested them with the Multi meter.
That’s correct. Power seems to be getting to the contactor but then I’m not sure.
Reply to Garage Heater Hardwire Help in the UK Electrical Forum area at ElectriciansForums.net
Interesting item you have there. This blog might be worth a read https://sllipblog.wordpress.com/2014/04/29/its-now-00-28am-and-i-need-my-bed/...
  • [DIAL] What Is The Cancellation Policy For Expedia?
    π”Όπ•©π•‘π•–π••π•šπ•’ 𝕠𝕗𝕗𝕖𝕣𝕀 𝕒 π•˜π•–π•Ÿπ•–π•£π•’π• 𝟀𝟦-𝕙𝕠𝕦𝕣 π•”π•’π•Ÿπ•”π•–π•π•π•’π•₯π•šπ• π•Ÿ π•‘π• π•π•šπ•”π•ͺ. π•‹π•™π•šπ•€ π•žπ•–π•’π•Ÿπ•€ π•ͺ𝕠𝕦 π•”π•’π•Ÿ π•”π•’π•Ÿπ•”π•–π• π•žπ• π•€π•₯...
  • Song words.
    All I Wanna Do Is Make Love To You View: https://www.youtube.com/watch?v=OAfxs0IDeMs
  • What is the refundable option on 𝔼xpedia? Cancellation Policy
    What is the cancellation policy for 𝔼xpedia? π”Όπ•©π•‘π•–π••π•šπ•’ 𝕠𝕗𝕗𝕖𝕣𝕀 𝕒 π•˜π•–π•Ÿπ•–π•£π•’π• 𝟀𝟦-𝕙𝕠𝕦𝕣 π•”π•’π•Ÿπ•”π•–π•π•π•’π•₯π•šπ• π•Ÿ...
