Hello Guys
Going to be installing power and lighting within a garage.
I have been told the walls will be covered with ply wood once the install is done.
The fuse board and accessories will be mounted on woodern battens.
the only t&e that will possbily require mechanical protection will be for the lights at high level.
Am I correct in saying because they will be higher than 2.25m I dont need mechanical protection?
