Garage Lights
B
brizospark
Client wants 2 x fluo's installed in garage
Would like to take supply from DB in house but very difficult to get access to with wood flooring down etc.
Would it be acceptable to extend the upstairs lights by taking a feed from loft (upstairs lighting JB) running SWA from eaves to garage via catenery wire and installing 1 x switch and 2 x lights in garage?
It dose sound like a weird way of doing it but if that is your only option.
As above work out the flc of the light circuit, if your spur cable is >50mm deep and the rest is surface mounted/swa, no need for rcd but better if it was.
