Hi everyone
Can I have your advise please?
I have a domestic detached garage to wire up. Its a simple job. 1 x socket and fused down for a single light.
They had a new roof on and want me to use existing supply cable, it comes from house CU that has RCD protection on its own CB up into the loft down the wall and under the patio. It was coming into an old fuse board on the garage floor. I'm getting rid of that and running in 20mm plastic conduit.
My problem:
Supply comes up 6in from the back wall through the garage floor. I want to protect with something like a terminal conduit box but that wont be deep enough - or perhaps a large bore bent conduit that I could slip my 20mm into when it gets to the wall - but then I dont have any idea how to fix that to the floor around the existing cable.
Kind Regards, David
My problem:
Kind Regards, David
