The power to my garage is supplied by a fused spur in the house. When switched on the fuse in the spur blows and the RCD trips! I found that a live wire had loosened and was hanging out of its connection! Could this be the cause of the problem?
Discuss Garage Power Supply Problem in the DIY Electrical Advice area at ElectriciansForums.net
Thank you very much that's extremely helpful!reconnect and see.
Reply to Garage Power Supply Problem in the DIY Electrical Advice area at ElectriciansForums.net
