M
Mewff91
Hi guys new to this looking to run power to my garage from the house cOnsumer unit. The garage is seperate from the house.
I was thinking as the board is dual rcd of running 4mm cable from a 32a mcb to outside then swa in 4mm to garage.
In the garage i will go into a new enclosure and run a 20amp mcb ring circuit, reason for 20amp is thst im only having three sockets in the garage and will not be doing any heavy work.
I will then run a 6 amp circuit for the lighting
I know its a lot to take in but does this seem logical and will it comply with the regs?
Cheers guys
Cheers guys
