T
tawraste
hi all,
could you please advise me on the following?
assume a small consumer unit in an outbuilding, connected via swa cable to the main consumer unit, and supplying a simple light circuit and a ring with 3 double sockets.
now if the whole thing has an rcbo at the main consumer unit, do you then need to put another one in the garage? and after that do you need to put rcbos or rcds on the small circuits themselves?
for instance,
45A rcbo at the main cu followed by 40A rcbo in the outbuilding, followed by a 32A rcbo for the sockets and a 6A rcbo for the lights.
surely this is rcd protection gone overboard? let alone very expensive!
cheers !
tawraste
for instance,
cheers !
tawraste
