Hi all,
Just wondering if some one could help me out on this one, i have a split load RCD board in the house and I plan on putting a new supply to the garage. I am thinking of running a 6mm SWA off a 32a MCB (RCD protected from the board) to a new garage CU, the garage CU will have a;
main isolator switch
20a RCD - radial circuit
6a RCD - lighting circuit
On the radial it will have 5 double sockets with such items, TV, small fridge, dryer and a plug in heater, they won't be used all the time just as and when.
The lighting circuit will just have 1 6ft LED strip light.
The SWA will be clipped direct outside and the cables in the garage will be in conduit. I planned on 4mm for the radial and 1mm for the light.
Is this over kill or am I on the right path?
Any help and advice is greatly appreciated. Thanks
