garage unit | on ElectriciansForums
Discuss garage unit in the Talk Electrician area at ElectriciansForums.net
Provided it's protected and it is on an RCD either in garage or main cons unit, should be O.K. I would run a 6mm earth with it as well. distance is relative check earth loop.
I would consider running the supply cable in SWA rather than T&E. Also it should be RCD protected at the consumer unit so that the whole circuit is RCD protected. I would also consider the earthing arrangements, as if it is a TNCS (PME) supply, then it is not permitted to take a PME earth outside the main building unless the earth CSA is the same size as the main earth conductor.
I would also do a full cable calc and determine what is going to be used in the garage as this may have a bearing on the supply cable size as will the installation method of the supply cable, ie buried in the ground etc
Reply to garage unit in the Talk Electrician area at ElectriciansForums.net
My wife’s Evoque gets about 32 miles on a full charge and I get about 28 miles on my F-Pace. I don’t know how long a full charge takes but I...
Sounds more positive.
