Hi all new member here.
First of all im not an electrictian, i have a sparky mate but hes on holiday and i wanted to get advice to get everything setup for his return (im aware of part p regulations etc so wont be doing it all myself).
Anyway just moved house and need some extra sockets in the single garage. Its a detached garage which has a armoured cable connection to the main cu via a mtn 116 hager 16a type b breaker.
In the garage is a little cabtree unit with a 6a breaker for the light, and a 16a type b breaker for the existing double socket.
Thats the existing setup, and this is what i need:
8x double sockets total.
2x above garage door for security lights (connected by fused plugs) and cctv cameras.
2x on each sidewall (1 will be used for another security light, the rest for occasional tool use).
1x external waterproof double socket unit.
Plus the existing double socket on the back wall, which will be used for:
1. an outdoor extension cable used for a fish pond
2. an outdoor extension for a light and thermostat tube heater in a dog kennel.
Being as there is only 1 double socket currently its just 1 cable runing strait to the socket with no return, which correct me if im wrong makes it a radial circuit?
What i want to do is run the cables and fix all the sockets to the walls ready so my mate can just come in and wire it all up to comply with the regs.
Will a 16a radial handle this? and due to the load is there any special wire specs i need to follow or use existing sized cable?
Or should this be converted to a 32a ring circuit? (which i guess would mean new breakers in both cu's and different cable sizes?
As i said above ive already mounted the backboxes and pvc trunking, just wanted to run the right cable and get any breakers if needed ready for when my mates back so he can actually make any connections.
