Garage Wiring Question | on ElectriciansForums
Discuss Garage Wiring Question in the Australia area at ElectriciansForums.net
A
Andyr86
Hi guys,
Been asked by a friend to put a socket and 2 lights into his garage this weekend (weather permitting!) and have come up with the following plan:
http://i.Upload the image directly to the thread.com/OcZTT.jpg
All using single core cables enclosed in 20mm PVC Conduit. The garage is fed by a 15m long run of 2.5mm2 SWA (already installed) protected by a 16A MCB on the CU.
As far as I understand the current regs it is accecptable to have a light running off a socket providing that it is protected by a 6a fuse (in this case in the form of an FCU, which also provides control). Can somebody please confirm this to be the case?
Will I require a way of isolating the socket from inside the garage and if so would a seperate FCU be accecptable?
Finally, do I need to get this work signed off by a certified electrician?
Thanks for any assistance given,
Andy
Does the house CU have RCD's? Any particular reason for selecting singles?
I was under the impression that if you are using PVC Conduit then singles need to be used? Would prefer using T&E as its cheaper.
yes you an take lights off a socket using a FCU but the fuse will be a 3 amp why weather permitting doesnt the garage have a roof ??
Just me being a wimp :p. Will make sure to use a 3A fuse tho, thanks.
Reply to Garage Wiring Question in the Australia area at ElectriciansForums.net
