garage wiring | on ElectriciansForums
Discuss garage wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
A
adavis
Working on a house that has the wiring in the garage chased in the wall and filled. Am I right in thinking the regs now say it has to be surface mounted or in conduit on the surface?
Adam..
Adam..
No it doesnt but if its less than 50mm into the wall it needs RCD protection. However if you aren't working on that circuit it is not your concern unless you can see some glaringly obvious danger which you must bring to the attention of the homeowner. If you are working on it then you will have to make sure that at least the part you are working on is brought up to the current regs etc.
Adam..[/QUOTE
The amount of myths and nonsense and misinterpretation of the regulations which become 'common knowledge' is staggering.......bonding is another favourite for total nonsense spouted....and if I had a quid for every time I hear 'My fuseboard is illegal'....I'd be retired in St Lucia by now.
Reply to garage wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
And if it's a garage then use metal clad accessories.
My wife’s Evoque gets about 32 miles on a full charge and I get about 28 miles on my F-Pace. I don’t know how long a full charge takes but I...
