Garden cables routing | on ElectriciansForums
Discuss Garden cables routing in the UK Electrical Forum area at ElectriciansForums.net
C
craig1000
Hi all now i know the regs etc for cables buried etc & sure i can remember reading there not to clipped to fences etc as they do not form a secure fixed structure, cant remember where in regs book, maybe I'm wrong as been scanning the book this evening.
Tin hat time i guess, in reality if the customer want power a-b & it is not possible or customer will not allow digging up of their lawn, flower bed, drive or whatever, & no wall available where can we run cables or is it a simple no cant do the job?
Fences for example if iv read the regs correct aren't classed as a fixed structure for the running of cables yet I see lights installed along fence routes ll the time! either im wrong or many people ignore that rule!
Have a couple of garden lighting jobs to loo at & want to know where I stand! What also about getting power along fence for a socket or hot tun at bottom of garden. It s afar better price for customer if I just install cable or conduit along fence as soon as the ground needs to be dug they'll be put off by the disruption & extra cost!
If you want to abide by the regs then they believe that it's safer to leave the cable on the ground than clip it
To a fence. I can see both sides of the argument to this one as I believe it's safer on the fence. But if it blows down etc then problems could arise. Telectrix once told me that he would fix some wood across the fence from post to post and clip it to that
Every job is different so you will have to make decisions regarding the positioning of the wiring system. You could run a SWA along the side of a path or under stone slabs, along the base of fences or batterned to the bottom of a fence.
Most gardens where the client wants feature lighting and its not a complete design or new build doesn't want their plants disturbed so it is unlikely that you will be able to dig it all up.
Never ceases to amaze me, these people that want electrical supplies in there garden, but think more of the dammed plants and lawns than their own and others safety!! There is no way i would leave an energised supply cable laying on the ground, armoured or not!! ..end of!!
The problem with fixing to these pre-cast concrete fence posts, is that you end up with bloody great chunks out of the concrete (exposing and leaving the steelwork to corrosion) because they are full of steelwork that is literary just under the outer finish.
Nah , its a piece of cake to put fixings in concrete posts , just drill without hammer-action to reduce cracking.
And if you know where the steel rods are inside ( which on a standard slotted i-beam post is in each corner ) you wont hit metal.
Practice makes perfect as they say.
All i can say is that the construction of those precast concrete fence posts must have changed a hell of a lot. If you didn't use hammer action you weren't going anywhere!! They use to have more steel bars in them than the concrete encasing them!! lol!! Same with the precast concrete panel garages, if they still make them. Bloody nightmare to get a fixing in them, if you weren't hitting steel you were taking lumps of concrete out of them!! lol!!
Its only dangerous if you hit it with a spade..... and then the RCD operates immediately. I'd be more worried about damage to the sheath and the eventual corrosion that will eat into the armour over a couple of years
Depending on layout of the garden and cable run then how about a catenary wire if no other way possible? No digging and as long as you have a secure fixing at each end, i.e the house wall and your shed or garden wall at the end then could get you out of trouble. Could even have it running along side the fence without having to actually fix it on to the fence itself. Just a thought!
Hello biff55, I'd love to watch that.
catenary wires are fine for a straight run from building to building or post but not really suitable for running a cable wire around a garden, particularly if the purpose of the lighting/power is to show off the plants, shrubs, water features, statues, sculptures et al.
If I couldn't bury it, I'd be inclined to run the SWA inside some polythene cable duct to protect the sheath from garden tools. (Like the blue underground water pipe, but black.)
Reply to Garden cables routing in the UK Electrical Forum area at ElectriciansForums.net
BS3871 type 3's have a similar shaped operating curve to BS60898 type C's. Any fault that will meet the disconnection time of 5s (for 63A...
