Garden deck lighting | on ElectriciansForums
Discuss Garden deck lighting in the UK Electrical Forum area at ElectriciansForums.net
K
krisbel
Can anyone help. I have a job fitting some deck lights in a fairly big garden. Al kits i have come across dont seem to have enough cable for connecting the fittings to the driver. also all seem to need plugging into an indoor socket. The customer requires them to turn on with existing outside wall lights. Can anyone suggest any decent kits or alternative ways to sort out my problem??????????
cheers
kris
As above, or mount a weatherproof JB with supply from outside lights and connect the transformer into this. Extend the ELV cable to the lamps with weatherproof in-line connectors and suitable cable.
Reply to Garden deck lighting in the UK Electrical Forum area at ElectriciansForums.net
As littlespark says there's no ways you're going to find spike lights that can accomodate SWA cables directly into them.
Is it a retaining wall? If so I'm of the opinion penetrating damp is almost impossible to avoid. Make a channel underneath for runoff and slosh...
