Rockingit
Mentor
Supporter
Just want a quick foggy-Monday-morning-brain check..... Customer wants a mixed feed for general outdoor shenanigans, plan is to run a supply from a KMF in the meter box down some 10mm SWA to an outdoor pillar style distro and then go from there. If divorce it at the pillar box, so the entire downstream system of 'whatever' is TT, will this still be compliant for a hot tub?
"hot tub, hot tub, do you require TT?"
Well this is it - without knowing what they're going to buy and the instructions that come with it, it's anyone's guess! Unless...... I guess could always put an earth mat under where it will go instead of a rod at the pillar.
Rockingit
Mentor
Supporter
Somerset
United Kingdom
Garden / Hot Tub / Pond pumps feed
Rockingit,
pc1966,
