L
Lloydus
Fitting two security lights in my garden. Only small 60w lantern type, one has P.I.R. I want them both to come on when movement is detected and also both on permanently via switch if needed.
Is this the right option? will it work?
Coming off the lighting circuit, straight into light 1 then connect switch wire and neutral to light 2 which will be P.I.R as well. Light 1 is not.
Come off light 1 with feed and switch wire to internal switch.
