P
pburley
Hi I've been asked to install some garden lights around a garden. There is a wiska box on outside wall, this is fed .direct from consumer unit (has it's own MCb 6A, RCD protected). gu10 mains lamps are going to be fitted (6 of, max 180 watts in total) about 50 metres of armoured. Is it ok to use two core (the lights don't need an earth) or should I run three core to junction boxes. Many thanks Pete
