R
redface
what would you guys use for lighting trees up.
i will have the light abouth 10m away from a 20 m high tree and and about 8 m wide. i think metal clad 150 w 35 degree spot so i dont lose light on other things in garden.
is there a good web page for this
also i have 200m of garden walk way near fence to dim light what lighting would you use .
i just want to know you have the same idea as me also can u get 2 x 2.5mm cables in a light or do you think i should do jb to light.
the lights i think i will run in pvc conduit and i think i will have a t box at each light and each tree light will be in swa because i will be going under lawn.
also will be having plant lighting i was going to put 12v lighting in so transformer will be fed from swa to ip rated box then flex to transformer.
is there a way of doing garden lighting easy or is this the best way
i will also be installing cu in to old stable and will have ir switching to contactors and cu in potting shed at end of garden
its a big garden and a big job that has been going on a year advice would be good or if u want more info just ask please
or do you think i have good idears?
oh thay dont want leds just sofl lights on walk way but want plants lit well and trees.
