Garden shed feed | on ElectriciansForums
Discuss Garden shed feed in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
albi
north east england
HI BOYS AND GRILS BUT AM I RIGHT IN THINKING THAT A CAN CONTINUE THE EARTH BONDING TO A GARDEN SHED FROM A TNS SYSTEM THERE IS A 3 CORE 10mm SWA FEED FROM A 32A B TYPE MCB WITH RCD AT THE SHED COVERING A RING AND LIGHTS. OR DO I NEED TO DROP A ROD DOWN AND NOT CONNECT THE EARTH AND MAKE THE SHED TT. CHEERS FOR ANY RESPONCE
Sounds ok to me.
The armour needs to be earthed at the CU tho, even if you are using a seperate conductor for earth.
Check out this PDF from the IET ;)
http://www.------.org/publishing/wiring-regulations/mag/2005/16-elect-inst-outdoors.cfm?type=pdf
I was told that if the house was a tt then you would have to have a seperate earth for the shed due to different earth potentials, but on a tns and i think possibly a tnc-s you can use the suppliers earth. Don't quote men though, as a mate of mine said to me last night "you can stick 10 sparks in a room and ask the 1 question and they will all have a different answer." lol
Reply to Garden shed feed in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I hate it when a shed is TTd, why can they not be extended from the tn system? popcorn ready
