Gardens lights wired in flex | on ElectriciansForums
Discuss Gardens lights wired in flex in the UK Electrical Forum area at ElectriciansForums.net
A
aaelectric
Im think of wiring some garden light which are high up on wooden panels.would you say it has to be in armoured or is it ok as it can be seen and no trees or bushes for it to get accidently chopped. All rcd of course. Any reg against it?
Cheers
As long as the flex is appropriate for the conditions, then no problems with it. By conditions, i mean length for volt drop, and external influences for temperature and climate etc. There will be other considerations as well, but i cant think of any at the moment.
Cheers........Howard
Have a look at regulation 559.10.3.2 and if your lighting falls into any of those listed then yes you should provide additional protection by RCD characteristics to 415.1.1.
If not regardless of being inside or outside a lighting circuit does not require RCd protection, unless it is for other reason associated
Reply to Gardens lights wired in flex in the UK Electrical Forum area at ElectriciansForums.net
Its important to remember that a plug top fuse is just a rewireable fuse that's convenient to change and shouldn't be confused with a HRC fuse...
