Hi
I have to connect up a gas boiler and know how how to do it with a volt free room stat.
What I need to know is can I use the relay/switch on a motorised valve to control the boiler via the volt free contacts in the boiler,and use 220v room stats to control the valve.
Its a two zone system and I cant work out how to control 2 zones valves from a volt free room stat.
hope this makes sense.boiler is a volkera
Thanks in advance.
Thanks in advance.
