R
richy8ball
hi i am faced with the following scenario:
the kitchen in question has a 45amp cooker switch above worktop level wired in 6mm2 cable on a 32a mcb. this cooker switch has a load in 6mm2 taken down to the cooker spout. im assuming this will be fine to connect the 2.35kw electrical oven into using 6mm2 cable. the problem i have is that the hob is gas and has a flex with a plug fitted with a 3 amp fuse, where can i plug this into? where can i get my supply from etc?
if you could help would be most appreciated...
