gas hob ignition | on ElectriciansForums
Discuss gas hob ignition in the Australia area at ElectriciansForums.net
Daveyboy
Hi guys, if you have a job where customers has a new gas hob and electric oven. Can you put the ignition from the fused spur feeding the oven or an have an individual switch? Or would the socket supplying the ignition need seperate isolation? Thanks
if the grid switch is supplied from a RFC ( as i assume it is ) then you could easily come off the supply side of the grid switches to a FCU for the ign.
Reply to gas hob ignition in the Australia area at ElectriciansForums.net
Although it might appear that I am being elusive with the facts, the point is, only you know what your worth is per hour and how long it will...
    • Optimistic
