M
mogga
Im doing a commercial site the gas meter is well within 150mm of db Code 2 or 1 ? altho theres not much can be done to remedy the situation
Discuss gas meter in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
That's one thing I've noticed when testing rcd's and rcbo's, there is a small spark sometimesfor any problems to arise, you would need an electrical fault ( arcing) and a gas leak. this could happen if the DB and gas meter were 6 feet apart.
Reply to gas meter in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
