Gas or Water Pipe? Look to find cause of damp in wall. Discussion Thread | on ElectriciansForums
Discuss Gas or Water Pipe? Look to find cause of damp in wall. Discussion Thread in the Plumbers Forums area at ElectriciansForums.net
This is an RSS feed of thread: Gas or Water Pipe? Look to find cause of damp in wall.
Content of the thread: Hi all,
First time post so please be gentle.
Trying to ascertain if damp wall in our kitchen is being causes by rising damp or by a seeping pipe.
The pipe in the image attached disappears off under our solid kitchen floor (back addition of a 1890's Victorian terrace). The other end disappears underneath the floor in the other direction, BUT I can't find it reappearing anywhere else in our accessable crawl space and it doesn't appear to be linked to our current mains water or gas system (as far as I can tell, but it's a real maze under there). I also can't find any appearance of the end that goes off under the kitchen floor (as pictured).
Therefore I'm wondering if this pipe is now redundant as part of a previous system that got updated at some point which would lead me to think that it might not filled with anything.
I've tried turning on mains water and it doesn't seem to be flowing in that pipe, but there might be a very slight vibration in there when mains water turned on (if I'm not imagining it), which makes me wonder if it might still be filled with water but just capped off somewhere under the kitchen floor (and maybe seeping, causing the damp problem).
However, my main question is... Does this pipe look like it is a Water pipe or Gas pipe?
Many thanks in advance for any help!
Gas or Water Pipe? Look to find cause of damp in wall. to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Reply to Gas or Water Pipe? Look to find cause of damp in wall. Discussion Thread in the Plumbers Forums area at ElectriciansForums.net
T
What plumbing tape is recommended for a copper waste water pipe Hi there, We have a leaking waste water pipe which our washing machine, boiler and...
Tellie
T
This is an RSS feed of thread: Banging on mains water pipe, could an issue with the water mains cause it? Content of the thread: Hi everyone, for...
