H
horsleya
I have a question regarding my own property which does not appear to have any main bonding on the Gas Pipe. The Gas meter is in a box on the outside of the house. the feed comes into the house at Three seperate points. One at the front for the gas fire, once along the side wall for the Gas Boiler and once at the back for the Kitchen Cooker.
The question is where do you connect the bonding? The CU is nearest to the Boiler.
I understand that the connection should be close to the Gas Meeter but as this is outside should it be connected outside or at one (or all) of the points of entry into the building?
Hope that is clear!
Hope that is clear!
