Gate openers. | on ElectriciansForums
Discuss Gate openers. in the Australia area at ElectriciansForums.net
Deleted member 9648
Been asked to rush a cable in for a 5 bar gate opener while some ground is already up......whats the typical load of such an opener so I can calculate cable requirements before tomorrow?
Thanks in advance
B.I.L got solar powered charger and battery powered gates due to distance from house meaning cable was prohibitivly expensive and would have required a massive box for termination
to work out size you need ALL the information
Reply to Gate openers. in the Australia area at ElectriciansForums.net
T
Megaflo UVC - Very Loud Noise When Hot Tap Opened Hi, I have noticed that when a hot tap is opened for the first time after a heating cycle (in...
techweb
T
Hi, I need to rewire a mapping/traction control switch on a race bike that was damaged in a crash. The switch is not stock to install some other...
