Gemini Advanced Microprocessor Control home alarm | on ElectriciansForums
Discuss Gemini Advanced Microprocessor Control home alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Gill sans
Worsley
Hi, I've just moved into a 1900 house with an existing home alarm. It says on the box that it's a Gemini Advanced Microprocessor Control. I don't have the manual but would like to change the code. The previous owners didn't know the code either.
Is there an online manual or a way of changing the code so that I can use it?
Any help is much appreciated.
you have posted in the wrong forum. let me ask mods to move it. a member goes by the name of tazz is your expert on alarms.
You can check out the manual you need from Leesparks link, if you find it hard to reset, replacing the control panel is a cheap and simple option.
Reply to Gemini Advanced Microprocessor Control home alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Oddly enough, I do actually have a wind-up megger! It sits on my curiosity shelf beside my AVO which, sadly, I can't get to work despite buying an...
