M
madgolfaddict
Grateful for some advice with this one.
In addition to my normal consumer unit I have an addtional consumer unit that was once used for storage heaters. Each Volex16 CB supplying one heater. Over the years the heaters were removed and the outlets converted to single point plugs. (the economy seven meter was removed)
One of the CB has had the wiring to the old heater disconnected and a new ring main connected to it.
Q1 Do i need to upgrade the Volex 16 to a 32 for the ring and if so can you get VB32 the same physical sixe as a VB16 to fit the same consumer unit?
Q2 Do I need to have fitted an RCB circuit protection for the ring?
Thanks for your replies for a newbie
madgolf
madgolf
