T
ta-electrical
1. Discharge lighting is on a 16A mcb, can it stay this way or will it need to be updated to RCBO for the new regs?
2. Radial sockets 50 metres away, on 32A RCBO, wired in singles, in trunking and conduit.
What size cable should be used taking voltage drop into account?
3. 3 phase motor with rating 3000W, 50 meters away, 2.5mm singles.
Will the voltage drop comply with new regs? Or shall i use 4mm cables?
Thanks in Advance.
Thanks in Advance.
