generate electricity please help | on ElectriciansForums
Discuss generate electricity please help in the Australia area at ElectriciansForums.net
V
villar
Hello. , Good afternoon. I need to know if
these work.
An elect. motor 3 hp at 220 volt. 10. 7
amps. 3600 r.p.m. Power from house s elect. pannel
May move a generator 6.5 kw
36 amps at 3600 watts r.p.m.
My question. Once power the generator
could i cut the current off., and feed the motor from the generator.
motor 10. 7 amps
generator. 36 amps
36 amps -10. I7 equals 25.83. Remaining amps. can this be use 25.83 in the electrical lines
such of lights,radio,tv, thanks.
What you are proposing does / will not work if it did electricity would be very cheap and very eco friendly, the electric car would never need charging and would run forever once started
Perpetual motion is the physicists holy grail and not I'm not sure it's one that can be cracked
I think the confusion here is that you are looking at the current and not the power. efficiency = power out/power in*100 and you are proposing this setup is over 100% efficient.
The reason it would not work are losses in the motor and the generator ie iron, copper, friction and windage for a start. you cannot get out more than you put in. If it would work power stations would have generators driven by bigger motors and no external power input.
If you do get it to work could you let me have the plans in private as I know some people who may be interested (Drax, e.on etc)
Well if you get a bike , add a dynamo , regulator ,deep discharge battery and an inverter you can charge the battery from the dynamo when you cycle the bike and power tvs from the inverter and as a bonus keep fit at the same time , my nephew came up with the idea of just that and when he watches TV he's peddling his bike at the same time so no couch potato there
please do not mention big generators., Petroleum Industry it is a big business.for the generatos
and somehow i will find the answer for this project. even if i have to get power from a gearbox. i will let you know if it work.
food for thought.
A thought long ago that I might be able to power a starter to start only a modern self contained steam engine running a turbine to produce electric. being that the engine would produce enough energy to run its self with an electric element producing steam as a feedback relationship producing motion. then a second geared turbine ( low resistance) producing electricity for other use.
Its a scientific fact that water once boiling needs a lot less energy to keep it boiling than making it boil.
as an electric car the engine would probably be too heavy but as a stationary object????
Would that work when put to the empirical test?????
:rolleyes:
The idea being: using energy to breed energy.
There are many ways to produce energy. that the government does not want you to to know . . because of the petroleum industry.for example. two generators connected in series one to feed to a motor and the other generator to electrical lines.
if every body had a self sustaining energy source in there garden the government would lose out on millions in taxation. If you made one and then marketed it everyone would want one and as soon as I bet you'd end up in the mental hospital pumped with drugs and a label insane. :eek:
Reply to generate electricity please help in the Australia area at ElectriciansForums.net
