Generation meter change? | on ElectriciansForums
Discuss Generation meter change? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
P
powervan
Hi lads been to job today where loose connection in generation meter has ment meter requires changing!(terminal is burnt out) 2 questions !1 what is the routine for changing meter on an instal completed by anther company who closed down 2 weeks ago( can i amend the mcs data base??) 2 has it got to be same make or can i fit my usual elster (as ive got one:)
not sure, but im going to look at one soon same thing, i was thinking send notification to FiT licensee EON or who ever and note it down on the MCS cert old meter reading and new SN
Have you spoke to MCS for their advice? If the 50 meters are registered with same supplier then I don't think it would be much of an issue. Just a phone call should sort it.
The only thing i can see on an EON FIT application form under section 11, is an area where you can change the generation meter details giving the new meter reading etc.
Reply to Generation meter change? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Afternoon! Hoping someone has experience working on the ABB gear below. It’s in a Mobile Office/ Welfare unit, supplied via either 230v hook up...
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
