Generation meter positioning ? | on ElectriciansForums
Discuss Generation meter positioning ? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
1973millerman
Hi
where is the best position to put the generation meter
1. Next to the main metering supply. Or
2. In the garage by the inverter
The inverter is about 15 meters away, from the mains point
Cheers
Without digging out all the guides, the condition you have to meet is that it is convenient to read. Probably the most important consideration is to put it where the customer wants it.
Be aware that if you have a long run to the garage then the lifetime cost of putting it in the house rather than the garge will be significant.
Regards
Bruce
Reply to Generation meter positioning ? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Thanks guys, that was my alternative thought, as I am running a cat 5 cable for Internet so it has crossed my mind to run another one for the CT...
I have an "old school" electricity monitor similar to this one...
