Generation meter readings ?????????? | on ElectriciansForums
Discuss Generation meter readings ?????????? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
1973millerman
Hi All,
New to the site, i have installed my first system last week, it went fine. Solar world system 3.92KW with Sunny boy inverter.
A Question... on the inverter it says it has produced 43.5KW in total to date, but on the generation meter it is only showing 5 units, are these figures correct, it seems that for this size system, not many units are being produced on the generation side, the weather has not been great down this end of the country
Has something gone wrong with the system ?
Hope to hear from anyone... Cheers
[ElectriciansForums.net] Generation meter readings ??????????
@1973millerman,
I know it's not a lot of money, In that situation as a gesture of good will, we would have refunded the lost income to the customer.
What are your plans?
Well done mate, that's the right thing to do.
Reply to Generation meter readings ?????????? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
If the batteries are charged and the house is taking little then the full production of the panels will be dumped into the grid. As you have set...
Hello Ric2013, MJPD29 and westward 10. I have a multimeter that I tested the voltage with and before I open the socket up I use a plug in tester...
