B
blakeyat48
my friend has a stand alone 3-phase generator which is supplying a shredder he has asked me to install a compactor to the generator as well,from the generator there is a swa cable off two the shredder control box where the neutral cable is bonded to the casing?now my question is am i right to assume that this point is used as the generators connection between neutral and earth and if so can i also use this as the nuetral point to get 230v for the control circuit. or do i disconnect it and install a henly block and rely on the swa as earth back to generator and assume that somwhere in the generator the nuetral is linked to the casing.not much experiance on generators any help would be handy.
