generator problems | on ElectriciansForums
Discuss generator problems in the DIY Electrical Advice area at ElectriciansForums.net
B
bigerik777
Hi...could anyone tell me what would cause a socket on a generator to fuse the plug on the extension i put in it, to fuse itself to it and burn ...
So you plugged an extension lead into your generator? What did you plug into the extension lead, what load were you supplying?
Now where did i put my all seeing, all knowing Crystal Ball??
Reply to generator problems in the DIY Electrical Advice area at ElectriciansForums.net
On a 20kw generator can you connect the 30AMP plug to one service panel and the 50amp plug on a seperate service panel? I have two service panels...
It's a room where someone sleeps, so it's a bedroom. Minimum standards were set in the Parker Morris report in around 1963. Anything built after...
