spidersparks
Hi guys, been wiring up a 3ph 20kva generator set and auto transfer switch, mains supply is 3ph TN-C-S 80a cut outs, the set is a Perkins with deep sea electronics 6120 controller. The set runs ok until I turn on the circuit (ring final) that has the ups's in the server room on, the load is 13-14a in total over all three phases which is nothing for this set, then the controller says over voltage and shuts the set off the circuit tested out text book so no problems with that, has any one had this problem or knows anything that might be my problem
Many thanks
David
Many thanks
David
