rt5510
I purchased a portable generator and I need to wire up the transfer switches. I am using two Reliance manual switches so I can individually control breakers that will be fed by the generator (and manage load). This is the type of switch: 306A Pro/Tran 2 - Reliance Controls Corporation - http://www.reliancecontrols.com/ProductDetail.aspx?306A
I am using two switches because I have a main panel and a sub panel located in different parts of the house. I need to provide generator power to individual breakers in each panel.
I have attached a wiring diagram and was wondering if someone could take a look. Just want to make sure it's a good configuration and I'm not missing anything.
Thank you
Thank you
