Generators | on ElectriciansForums
Discuss Generators in the Australia area at ElectriciansForums.net
G
gerard
Hi,
As part of my college project I need to size and choose a suitable generator unit for my building(supermarket). Does anyone know of a good company that supplies Generators and where i could get information about this.
Cheers
As Tony says you need need to know the loading as when I worked for a company which looked after supermarkets which had standby generators, some would do the whole of a store but some would only do part of a store to cover fridges and freezers only
Thanks for the reply. I will know the load soon. Just need to calculate it.. I wanted to research about how they work and the theory of it all. So i am looking for generic information at this point
Reply to Generators in the Australia area at ElectriciansForums.net
On a small generator I wouldn't want to risk using diversity as they are not quite as forgiving as a mains supply and can very quickly fail when...
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
