Sorry to interrupt this thread but if you buy the dedicated IP65 enclosure along with the Elios4You (single phase version) it comes with glands/outlets for the CT leads and aerial, and a pre-assembled (and wired through the included fuse/fuseholder) AC mains lead with 3-pin plug. Not entirely sure that you need to have it fitted by an electrician in that case as it can just be plugged in. The CTs are split so easily fitted around existing phase wires.
Whilst I'm on the subject, the Elios4You is a very accurate (1-2%) monitoring platform that is designed to also provide a variety of control features. By default, the base unit has an on-board relay/changeover contact that is rated 10A. This relay can be configured within the APP (free for iOS/Android) for a separate upper and lower threshold based on either generation, import or export levels. As an external control feature, the new Power Reducer (immersion controller) kits will be available here in the UK by the end of this week - ours are in transit now. These will be controlled by the Elios4You unit via an on-board analogue output and provide fully proportional control over excess energy delivered to a resistive load (max 3kW) using PWM technology.
The Elios4You can operate in "direct" mode whereby it communicates with a smart-phone/tablet using its own internal WiFi network. However, when hooked up to an existing WiFi network in the property, the system operates in "indirect" mode and can also be accessed online via the 4-Cloud portal using any web-connected internet browser. Installer and end-client have separate log-in details to the portal, providing a different level of access/overview to the system(s).
Further along on the technology roadmap is the "Smart-Hub" which is a wirelessly controlled hub that can manage up to 4 wireless smart sockets/switches. Again, this device will be managed within the APP and controlled by the Elios4You device. Greenologic/4-Noks are hoping for release within the next month or two.
