M
macca499
Hi All,
We fitted a system a few months back using a PowerOne Aurora with a Geo Solar Chorus Monitor to enable the customer to view import, export & generation. The DNO came out to change his existing meter last week to an import/export meter and since then the Geo seems to be adding the import and export together giving a totally inaccurate reflection of what is going on. It seems the problem is that the DNO has installed a meter which has one led which pulses both for import and for export. I am trying to find a way around this to enable the Geo to differientiate between the two and wondered if anyone has encountered and overcome this problem before?
The Geo has 3 sensors, a stick on pulse sensor for the pulse output on the generation meter, a stick on pulse sensor for the pulse output on the DNO meter, and a CT sensor to clamp around the live into the DNO meter.
I am thinking the solution would be maybe to install an additional import/export with 2 led pulse outputs, one for import and one for export after the DNO meter but have struggled to find anything which fits the bil.
Any suggestions welcome
Many thanks,
Macca
Many thanks,
Macca
