German Switches | on ElectriciansForums
Discuss German Switches in the Australia area at ElectriciansForums.net
P
paulo78
Hi
I want to install switches from GIRA The KNXshop catalogue - an Ivory Egg businesshttp://www.knxshop.co.uk/catalog/Ca...eading=Pushbutton_-_1_fold&NavID=010-017-1084
Those in this Link are for a KNX Bus system but i want to use the GIRA type which controls the light Bulb directly. On, Off, Dimming and so on.
Now my Questions those switches come from Germany and they have a different system to fix them as the use round wall Boxes in Plastic. But they also have 2 Holes which allow me to fix them in our square UK Boxes. Is this allowed ?? Can i use those German switches ??
Regards
Paulo
I've worked on a Huf house in the uk and they use all german accessories and it's all been signed off with BC so would have thought it wouldn't be a problem as long as they are EN approved. Watch out for the two way switching they use relays not just physical gate switches.
Hi,
Thanks for the fast reply
I also think that it should be possible to use them, so that means i have to make sure that they are EN approved and then i´m fine ?
Anybody else out there who used German Style switches in the UK??
Reply to German Switches in the Australia area at ElectriciansForums.net
Hi Richard, thanks for your comment. The relay is rated 12A peak. It's also worth noting that a relay contact will perform differently depending...
    • Winner
You really need an inductance or LCR meter or a ring tester which are expensive to buy but you can make your own ring tester if you want a project...
