O
ollie_C
Hi guys,
Ive had an absolute mare with this so thought i'd ask you guys...
im trying to get the main fuse pulled from a meter ata clients house so that I can fit an isolator and change the CU, (although the CU will be done at a later date).
Ive been going around the houses trying to get someone out to do this! Ive spoken to the bill supplier (Eon) and theyve told me I need to go to the DNO (EDF), EDF have then told me to go back to Eon! I always thought it was the DNOs job but now im doubting myself!
Ive spent a fair few hours on the phone trying to sort this now, mostly to 0845 numbers!!
I can now understand the temptation to pull the thing yourself! Ive laso read on other sites that when I (eventually) get someone out, they will want certification for work done...what is the relevant cert for installing an isolator?? are they expecting tests to be done??
