Getting multiple electrician opinions on EV Charger | on ElectriciansForums
Discuss Getting multiple electrician opinions on EV Charger in the UK Electrical Forum area at ElectriciansForums.net
edd134
Virginia
Hello,
I'm looking into installing an EV charger in my condo that taps into the load of meter. I've gotten three very different opinions on if I have sufficient capacity to install the charger without also adding a 1.2k DCC that allows an EV charger to be installed without impacting peak load.
1. Electrician 1 thinks I can do a full 50 amps without DCC
2. Electrician 2 thinks I can do 30 amps (24 amp charger) without DCC
3. Electrician 3 thinks I have no safe capacity and I need a DCC no matter what.
My meter is providing 125 amps- and my panel is also rated for 125. Is there a way I can validate who is correct? I tried adding up the total amps in my panel, but that's way more than 125 so must not be the way to do the calculate. Photo of my panel below:
[ElectriciansForums.net] Getting multiple electrician opinions on EV Charger
Reply to Getting multiple electrician opinions on EV Charger in the UK Electrical Forum area at ElectriciansForums.net
I seem to recall that written information for their approved installers listed an explicit requirement that it be wired and connected in all...
The last couple of de-loops that I have been involved with had the single phase supply replaced with a three phase cutout (as I believe the DNOs...
