Getting Part-P etc | on ElectriciansForums
Discuss Getting Part-P etc in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
T
TR7V8
Hi
I am 53 and have been a Radio/TV/Electronics engineer for 35 years, I now have a single contract with a manufacturer but may loose this next Jan.
Over the last 30 years I have rewired 10 or so houses, changed consumer units, added outside lights, garden supplies, house extensions and even a temporary supply in a building plot all to regs and all passed inspected OK. I wish to qualify with Part-P but do not know how I can achieve this without working for someone.
I have a good knowledge of 16th and now learning the 17th edition as I have been advised to take C&G2382.
My problem is that any type of course I have looked at cannot assess my ability, I have to start from scratch or be working for someone else.
I dont realy have any need for much practical training although would be happy to be assessed, is there a simply answer to this.
Regards
Chris
Part P requires the EAL VRQ after that you can register with the NICEIC or similar within 12 months you have to pass the 2382 17th edition.
Chris
Upvote 0
Not to my knowledge but I am sure someone will help I used ableskills in Dartford. You will need a copy of the Building Regs and concentrate on chapters 1 5 and 10 plus know all the parts ie part a structure part b fire
Good luck
Chris
Upvote 0
Elesca will take you with just 17th if you can demonstrate that you are competent enough to pass the assessment. Do you have much testing & inspecting experience because a 5 day EAL wouldnt show you those skills in any depth at all.
Upvote 0
No test or inspection, someone else always used to test and inspect my work, so is this sliding me down the scale to a full on course ? or do I look for some way of gaining a bit of practical experience in this area.
Upvote 0
The EAL VRQ contains inspection and testing but to be honest the actual exam you sit is all about the building regs. If you have a test meter Unite do a book that is very helpful on inspection and testing costs £7.00
Chris
Upvote 0
from what i hear you look at a tester once, hardly any use to someone who has never tested before is it. 2392 would be much more appropriate.
Hi
Dont get me wrong but are you saying I need this qualification or recommending it, I take the view that experience is very important but as an electronics engineer I would have thought I would be able to pick up most parts quite easily, on the other hand I would expect a tutor to advise on any shortfalls during a course ?
Upvote 0
With your experience you should not have to take it al all but the system wasnt well thought out (suprise suprise) its probably best to ring the various bodies and see if any will accept you as you are
Chris
Upvote 0
I also was a radio/television engineer (at least we used to be called engineers a long time ago) although I did a few years apprentice electrician before that.I just swotted up on the 17th edition,practiced with an exam simulator and passed the C & G 2382 with almost 100%.To anyone with electronics test/fault finding experience electrical test procedeure is just unbelievably simple so I would say just read up on it and practice doing it.The NICEIC Inspection Testing and Certification guide is good and also tells you how to fill in all the forms.I'm just going to have the ELECSA on site assesment now as that is all that is reqiured.They did say if you have no other electrician's qualification the 2382 is required before an assesment can be done.The 2391 2392 are not a requirement.I found it very helpful to phone NICEIC and ELECSA and ask any questions I had.
And another very helpful source is the NICEIC and Megger DVDs on inspection and testing and safe isolation.
Upvote 0
Thanks for the information, I did not wish to be the one to say it but I did think my experience as an engineer would make things easier, you just confirmed it, just having trouble with the C&G numbers now:D
Chris
Upvote 0
Reply to Getting Part-P etc in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
This situation is not uncommon and is absolutely nothing to lose sleep over. There are plenty of properties sold without the 'required' electrical...
Concerning isn't it. I fear it's just going to lead to reduction in standards and entry requirements and flood the industry with even more poor...
Electrical Courses
