Getting supply for a new light and switch. | on ElectriciansForums
Discuss Getting supply for a new light and switch. in the Electrical Course Trainees Only area at ElectriciansForums.net
T
turan_08
Hello everyone.
I have registered not long ago and would like to ask you all a question already. :)
I wan't to get supply for a row of lights which will be controlled by a different switch. Will I need to get the supply from a switch or the ceiling rose?
If the answers could be precise as possible, it would be appreciated. :)
Thanks in advance for your helps.
all depends on how the existing has been wired. time to get a local electrician to quote.
Best PM a moderator and ask to be given access to the DIY forum and have this post moved, questions from non-electricians in the general electricians forums rarely attract polite replies.
Or if you are a trainee then the trainees forum would be a good idea
I concur with this excellent advice.
This is the DIY forum isn't it?
Yes it is, I moved your thread. Now you have Trainee forum permissions I've moved it again because you won't be able to access it otherwise.
Reply to Getting supply for a new light and switch. in the Electrical Course Trainees Only area at ElectriciansForums.net
"It works" and "it's safe" are not necessarily the same thing. With DIY work, they are often far from the same thing.
Thank you so much for your help with this light work perfect now thank you again much appreciated
